Parts for Auto to Manual Conversion
Stack dilemma?
DD fuel pin
Has anybody done this, and if so how hard is it?
Also anybody have the pedal and hydraulics?
I need all but trans and bellhousing.
Thanks!!
Karl
I to am planning the swap from my old 90 5 speed to my 93. It should be easy for me because all the parts will be side by side. If i get to it first I will let all know how goes it.
auto tomanual conversion
I too am exploring process to convert to nv5600. by the time you rebuild and update an auto. you are 2/3rds there expense wise I believe. I only want to do this once! then no more automatic considerations, ie: temp,slippage,exh. brake,etc.
1. what is necessary flywheel wise.
2. is the clutch linkage the same for diesel or gas -if you are looking for used
thanks
cliff
Yes the linkage is the same but it is not linkage it is hydrolic. The hole is there to fit the mastercylinder into the auto chassy.
