Engine/Transmission (1994 - 1998) parts need to tab a kdp?
Engine/Transmission (1994 - 1998) Broken throttle rod
2nd Gen Non-Engine/Transmission 3500 Tire Pressure recomendations
What do I need to tab my kdp? I have a front seal leaking so I thought I would tab instead of jig.
I need a front cover gasket and front seal. But what else?
Wasn't there a sticky on the tab fix?
You also need a longer bolt (depending on tab thickness), loc-tite, a seal and gasket
For info on the tab fix contact Joe G at -- email address removed -- for excellent instructions.
Click here for a diagram of how the KDP tab is made.
For those who do not have the facilities to fashion their own tab, TDR Member R. ebel has made up a few tabs that can be purchased. Just PM him for details.
u can buy a tabs from Piers or i can send u one. The part #'s on the seal and gasket is 3918673 and 3804899. I can't remembeer which one is which. U don't need a longer bolt, but lock tight is recommended on a dowel pin that is out and on the bolt.
i was the same way till u see how weak a fender washer is to the chrome moly. I'm sure u'll be fine with the fender washer, ... but u're only gonna do it once, ... make sure u do it right
When I did mine I bought the seal and never used it as the original went on and off so easy with the guide included in the new seal I saved the seal for when needed. I did replace the gasket and found that the dealer had it off before me and just used silicone to seal it.
Bruce
Reb. B,
I didn't use a fender washer. I used a piece of scrap steel I had in my scrap box. It's a little thick, but that is not a problem.
KDP tab
Just don't use any hardened steel like sawzall blades and such. They can break off and your back to the same problem or worse. I used simple 1/8 inch band iron with a longer bolt.
