Past the point of no return
didn't know I did this
  • sorry
    Votes: 0 0.0%
  • sorry again
    Votes: 1 100.0%
  • Total voters
    1
Swiss cheese airbox?
Engaging 2nd gear while US Gear DeCelerator engaged
Ok guy’s
The first order is in Kelderman air ride suspension front and rear. 1st because I’ve wanted it so long. (And because I’m a wimp on rough roads) Also I want it in place for possible compatibility issues on the next steps.
When the parts come in I’m taking it to Denver spring to have it installed, rear first (rear is already 1. 5 inch over stock height). Then raise the front end by adding a leaf/ leaves and arching or what ever it takes to bring it up level (to the completed and properly adjusted rear).
Better chain clearance in the front wheel wells is a big one for me. I have running boards I always have to take off before hunting season because its just to tight behind the front tires.
2) As soon as that’s done, the exhaust system. Starting with (Right now I’m thinking) “Banks Quick-turbo assembly” And then the 3. 5” (3” around xfercase I’m told) exhaust system. I’m concerned the Air ride structure may alter the route a “Kit” exhaust system may take and will have to wait and see I guess.
3) Banks Techni-cooler Intercooler assembly, Gauges pyro, boost, tach
4) Some sort of cross flow radiator. I am concerned about compatibility with intercooler, routing hoses and ducting etc.
5) Drop the transmission, transfer case and gear vender in preparation for the BD Torque Converter #1060210 for the 89-93 250-300HP rear wheel trucks, and any other appropriate part I haven’t figured out yet. Transmission cooler? (I know I know my engine is still semi stock that’s coming)
While I have the transmission and transfer case down might as well have them rebuilt. Like the Wife said, “if you do this, you are going to drive it until you die”
6) Air delivery. Swiss cheese the air box? K&N, suggestions.
7) When the above is done, time for injectors and someone smarter than I am right now on the pump timing and output. I am reading all the posts on TDR “READY TO LEARN MORE”
I am also concerned about the 250-300 HP rear wheel torque converter and semi stock engine if there is an issue here; in the time before completing the B. O. M. B. ing of the engine! (I love that term now that I know what it stands for).
8) New paint graphite in color & clear coat when I can afford it. I am going to try to keep this cash only. It looks ok now. Priorities you know
9) Gray line X in the bed.
10) Interior
11) Borgeson Steering Shaft
12) Espar heater
This project is funded with $10,000 Cash transferred from the (2002 Ram fund) to the "your out of your ******* mind" fund. I’m ready to liquidate other toys as needed man I’m pumped.
If anyone sees any flaws in my approach or has any suggestions, please I want your input; it will be greatly appreciated. I am ready to learn.
I have every issue of TDR from number 1 to spring of 2000. Because I just rejoined I should get the current issue soon and order the back issues I missed even though the are mostly geared to the newer production. My old issues are full of sticky notes from the last couple of nights to start the process. A suggestion of other resource books, or whatever would be also greatly appreciated.
Thanks Jim Johnson
Hey JJohn!
Sounds great! I bought my truck as a neglected farm truck and have now probably put $10,000 in the old girl. Wouldn't be driving anything else!
Sounds like some SkyJacker 2 1/2" or National Spring packs will put your front end where you need it.
Maybe you can be the first to try a Piers "Super Turbo or a KwikKurt HX40-12cm2 if it's in the budget. :D
KEENO:)
Great pics... love the tent!
Sounds nice Kyle,
Have any pictures of that crewcab you can post? Sounds like I should add the borgenson steering shaft to the list from what I have read... Yes/no what is the all new r134A, Air conditioner maybe? Did you rebuild your np205 yourself or have it done. I would like to do as much myself as possible. I’m mechanically capable, just not all that experienced. Not touching the 727 transmission though, I’ll leave that to a good shop.
Kenno,
Looks like more research tonight … Piers "Super Turbo or a KwikKurt HX40-12cm2 As for the lift. Denver spring has done work for me before on this truck, and I trust they will know what to do. But I'll look into your suggestions anyway. Thanks
Last Photos taken,
As for Ac, IF your R12 still works, stick with it. R134A Cooling sucks in the performace area. You might want to just fix the R12 system if you want best results in the summer. The NP205 is really simple to work on, (maybe thats why it is so reliable). It does come apart like a chinese puzzle box (with the shifter forks). Read the manual and keep a VERY clean work area.
Kyle
:) Very good choice, you might take advantage of the special that Piers has on the Prince of Darkness injectors this month. I really like them and are easy to install. If you purchase the dial indicator and adapter tool, you can set the timing yourself, as it is hard to find someone to set it out of factory specs. Factory is 1. 25mm and about 1. 50mm is a nice spot to be. Good luck with the overhaul of an already nice truck. :) :) :) Tim
Hey Guys
Just noticed the activity on this old post. I still regret selling my 90. The 2002 is nice but its not the same. I can however hear the radio in this one!
The young couple that bought my 90 love it and are taking it to Alaska this summer with a slide in camper for there honey moon.
fboyle
No, just not as quite as the new one. I didn't mind it at all, I just couldn't hear the radio with the windows down without cranking it so much it distorted. It was fine with the windows up... but it had no a/c.
yep, mine seems to make to many noises when its idleing. I'll get some of that fixed over the summer. :D did you have a CD player in yours?? I'm wundering if it would skip??My portable one didn't and that would skip if you looked atr it funny:-laf
Frank
