Well,
I ve had my Ats manifold POD's And rip rook exhaust on for a week or so but i;ve been wanting on an PDR hx 35/16
Well got home from work today and there it was, i jumped out to the shop and started the installation , had it installed in about an hour, Primed it and fired the truck up for the first time in a month.
I did'nt touch any of my pump settings,( just bumped the timing up a hair) but first thing i noticed was the idle, it's about 150 rmp lower than before, and the idle seem rough, like a big block with a cam in it, but at 1000 rpm it smooths right out.
So first question is the idle suppose to be kinda lopey (rough)???
i jumped in and took it for a ride, first thing i notice was the turbo wine this thing is unbelievable is sounds like it's trying to suck my K&N inside out, time to put the Old Smokey back on, if you want turbo whine this is it, for a long trip i may have to put the silencer ring back in (NOT).
Seat of the of the pants feel, the turbo lag is slightly more than than the h1c with the 14cm but just barely, with a quick take off the line it does seem to smoke quit allot (but thats a good thing right???) but clears up some what a couple of miles down the road. as for power the truck seems to be quit a bit quicker, i have'nt really hammered it yet because of the new turbo, but i can tell you the DTT trans is getting a work out.
At 65 mph flat cruise the old turbo would run 5-10 psi boost, the new turbo runs between 2-3 psi at cruise but it only takes a tap of the throttle and boost is up to 20 +, on a steady acceleration up to 80 mph boost pegged my 30 psi gauge, so it looks i'll be getting a new boost gauge ASAP.
Rip rook Exhaust system fit like glove, i ended up ordering the system without a muffler trying to save some shipping weight, and bought a 9x27" dynomax performance diesel muffler, it is allot quieter than my old system which surprised me. seeing how i can just about put my whole arm thru the muffler and for the most part it's an empty shell with about 2" of baffle at each end.
that about it until i get a chance to drive i little more, any help with the idle problem, if it is a problem will be appreciated
Rick
Rick
