I assure you that blower is working before the turbo spools...
Forrest Nearing said:I assure you that blower is working before the turbo spools...
Scrappy said:I see a flaw it that car's plumbing,the way it is in the pics the supercharger isn't doing anything until the turbo spools. I say this because the supercharger pulls its intake air from the I/C and the goes to the y-pipe and the y-pipe goes back to the I/C so the charger is just dumping back into its intake until the turbo spools. they need to put a butterfly in the I/C side of the Y-pipe to keep it from backflowing.
RacinDuallie said:Mark- you mention HX-35 and the Blower- so is this a single or twin set-up here?
And you report on lower RPM hp numbers- what about the good upper numbers where you would use a setup like this at the big end of the track?
Or is this design for the street?
Seems like alot of money and work for ONLY a piddy little 350 hp... ... ... ...
Hasn't 350 hp been seen with JUST an HX-35? 400h. p. as well? (high EGT's but 400+ none the less?)
What RPM's have you seen this set-up choke off?
nascar mark said:Hey Bud,
You read it right. It has a HX35 and blower right now. The truck had a set of twins on it that we built many years ago. No hp monster, just a good everyday driver and towing rig, mild setup at best. The blower was added with the twins but for testing the twins came off and the motor changed with a good used motor. I dyno'd it with only a 35 first to give us a better base to test with as the old engine was tired and needed replaceing.
The blower was added with the 35 and I ran her with the same load and starting rpm's. Night and day difference. Snappy is a good word for it. The truck is a 5 sp duelly and it just jumps with each shift, even with feathering the go peddle.
The power comes in off idle and holds longer with this set.
This set up isn't designed for big power, just useable power. I would give up 16 hp any day for the power this makes down low (off idle to 2200 rpm) were most of us drive on a daily bases.
I wouldn't say the engine chokes off at all. It just gives up 16 hp for monster bottom end. The torque was 100 ftlbs higher in total than with just the 35.![]()
Still a little tweaking to do but I like the results for now, seeing as no tweaking was done so far.![]()
The Roots-type blower will build more boost at low RPM and becomes less efficient as RPM rises. A centrifugal, on the other hand, builds boost exponentially as RPM increases. If you're using a blower to build boost until the turbo comes on, you need help down low (Roots territory), not up high in the RPM band.biggy238 said:I Still would like to know what advantage a roots type blower has over a centrifugal.
jabird said:Is that to say a "kit" will be offered?
