Pennzoil 15W40 LongLife?
Geno's Exhaust Blanket kit
Surge breaks -Electric
Is anyone else out there using Pennzoil 15W40 Longlife besides the company I work for in the Cummins 5. 9? We have a 1989 1 ton Cummins with 224,000, a 1998. 5 3/4 ton 4WD QC , and a 2001 3/4 ton 4WD QC - all have been run on LongLife 15W40 since the day they had the first oil change. None have had any problems aside from the terrible post oil change rotten egg / oil smell. We change oil on a 6,000 mile interval (I consider this to long) and use the microglass or stratopore filters. Input anyone?
I have used it with no problems. I tend to switch around and try different oils (currently using Valvoline Premium Blue), but would not hesitate to use Pennzoil again.
'99 3500 QC 4x2, AT, 4. 10 LSD, camping/towing pkg. , Mag-Hytec rear cover & trans. pan, Auto Meter gages, K&N air filter, Mopar bed liner & mud flaps, Prime-Loc fuel filter relocation kit, Tekonsha Sentinel brake controller, Rancho step rails; Air Lift SD air springs
AWESOME PRODUCT!!!!
Love those 2. 5 Gal containers as well. .
One 2. 5 gal jug + 1 quart (which goes into the filter) is the PERFECT OIL CHANGE!!!!!
I've gotten it down to the 5. 0-7. 0 Min. change!!!
READY for the pits at INDY for SURE!!! #ad
Anyway. . I love the stuff...
I went "Inside" the valve cover to check the valve lash and found the inside so clean you could eat off it!!!
I was going to change to 100% synthetic . . but I change oil every 3000 RELIGIOUSLY... and I figuired NEW. . CLEAN. . PREMIUM Natural every 3000 beats... letting a synthetic that will have to go for 10-15000 just to break EVEN COST WISE!!!!!
Larry
Is this stuff rated C or S?
Joe George
Eureka, CA
'95 2500 CC auto 4X4,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Like any good oil, it carries all of the most recent ratings for diesel engines (CG, CH-4) as well as SJ for gas engines.
Ghostroller, best advice I can give is have an oil analysis done on one after 6000 miles. I use Blackstone, but several are pretty good. That'll give you hard facts for around $20 including postage.
