What you gain with the inner axle kit is strength. Your link failed, but I'm guessing the Perma-Lok simply engages the collar in the CAD permanently? With your new lockouts, you don't need the CAD, obviously, and you could probably do the same with a welder.
However, the pseudo-Dana 60 in these Dodges is really no stronger (maybe less) internally than an old 1/2 ton Dana 44 due to the wimpy axle shaft diameter (same as dana 44 with the added weakness of a 2-piece long shaft no less).
Of the 2 inner axle kits I am aware of to go with the hub kits being offered, the Dynatrac is undoubtedly the strongest and is a TRUE dana 60, 1. 5 inch (all the way) diameter. This was not easy to accomplish given the tiny CAD axle seal design and I understand Dynatrac had some problems with getting their seal adapter kits to work well. Supposedly, that problem has been fixed now.
EMS offers 1. 5 inch shafts BUT the passenger side long shaft necks down to Dana 44 size to utilize the stock axle shaft seal found in our fake dana 60's. They claim the shafts are made of superior alloy and are stronger than the stock pieces, but I remain skeptical. Necking a 1. 5 inch shaft down just wastes the rest of it since it is no stronger than it's weakest point.
If you do not run big aggressive tires off-road. If you do not install a limited slip or locker. And IF you do not put the full might of the Cummins to the test in 4wd, then keeping your stock shafts permanently locked together will probably work for now, but it is definitely weaker than either of the 2 aftermarket designs.
We essentially have dana 60 ring and pinion size and strength (not bad). Weakened, by virtue of the 2-piece design, scrawny Dana 44 axle shafts. A weakened dana 60 housing (the CAD housing really weakens it). It should at least come with a truss, especially given the weight of the Cummins. Wimpy outer axle shafts. Unreliable and weak balljoints instead of kingpins (no comparison at all in strength). Idiotic unitized hubs. ONLY the center pumpkin housing and ring and pinion are worthy of the Dana 60 name and reputation.
ANY upgrade in that front axle, steering, or suspension is a step forward from what daimler engineers sold us. Only an independent front end could be weaker or more troublesome.
