Permanently mounted booster cables wiring question.
Latest Software Update
68RFE DOWN SHIFT 2013 6.7 LARAMIE 2500 4x4 323 differital
Keeping in mind all the new sensitive electronics on the new trucks, I'm about to install a set of jumper cables with quick disconnect Anderson power pole plugs on the bumper.
1. Should I run the ground directly to the battery or should I go to a frame bolt?
2. Should I place a diode or fuse inline on the positive side to better protect the system?
Any other suggestions?
Thanks
Craig
I ran my ground to the big ground on the block.
I also put the hot thru a HD CD solenoid with a switch in the cab.
On my service truck I ran the ground cable to the frame.It was used on a few big rigs over the years without issue.I used heater hose over the cable as an added precaution against any unwanted welding even though I had used Many cable clamps bolted along the frame.Mounted sockets at both front and rear.
Most vehicles I maintain have whitaker type boost cable hookups. In HD spec, they're always taken off the starter motor as that serves as a the best binding post for both poles. In medium apps, a battery isolator is commonly used, especially if aux batteries are installed. The isolator offers good polarity protection.
I agree with the starter post being the absolute best place for the positive and the frame is the best place for the negative. No question.
Mike.
I would go direct to the battery for both hookups with one double post battery for that conection even better. A bad ground can cause all types of back feed problems.
Nick
