hasselbach said:I am going to order a BD BOV on Monday and see if it helps the bark that I get when I shift. Plus, I would think it will keep the turbo spooled up more.
I'll post the outcome once received and installed. I'm not too thrilled when I hear the bark, thinking it just can't be good for the turbo.
PATRIOT_Ram said:
Jim Fulmer said:If you look at the pic of the 66 in the bottom of the exit point you can follow the wastegates exhaust and see how it dumps aft of the wheel.
Jim
PATRIOT_Ram said:JCleary -- In the form they send it to you, the SPS66 will NOT fit with the Kore towers. I had Floor-It install mine. The 3 hour job ended up taking two guys all day long and then some -- but we made it work. There are two things that you'll have to do to make it fit. There physically isn't enough room for the turbo to fit in the "contour" in the kore tower. There just isn't any way. What we had to do was clock the housing on the intake side so that the snout was above the shock tower. They also had to grind part of the turbo housing down to make it fit -- but just the point by the snout so that it clears the shock tower. After that, you have to rotate the intercooler hose to make it clear. When it's said and done, there is VERY little clearance between the intake tube and the intercooler hose, and same with the shock tower -- but it does fit.
MMeier said:Will a Jacobs brake mount up to this thing?![]()
hasselbach said:Meaning?? Is this good or bad??
joaker said:So out of curiousity... . are there any of you out there using this superb turbo on a 2nd gen 24V? I am currently running a B-1, and it sounds as though the 66 is a superior unit... Will it act a lot different on my truck than on a 3rd gen? My b-1 spools very nicely, will this one be slower? I would like to run a bit more fuel into her, and think with the addition of the 66, I could do so and hopefully keep my EGT's a bit lower too... any help would be appreciated.
BrettWilliams said:Just wanted to let you know we are now shipping Phat Shaft hoodies (sweat shirt) with turbo orders. Just a change for the season. Thanks for your support.
