3.07 to 3.73 Gear Change Question ?
I'm working on a 90 D200 , took out the 3. 07s to put in 3. 73s. Didn't know 3. 07 housing is different and ran into carrier problem.
Not wanting to change the whole rearend I spent some time figuring this one out. My solution was to take 4. 56 carrier and machine off . 150 off the pass side to move over to the right side and use a . 150 spacer on the left side. Set up is good but one problem now , ABS magnet is not lined up with tone ring.
The owner says the ABS doesn't work as the lights are always on anyway and as far as he is concerned he doesn't want ABS .
Anybody done this gear change and how did you do it ???
By the way this truck has a US Gear Exhaust brake and dash gage cluster with pyro, ex temp & oil temp , none of them are hooked up and owner says I can have the stuff if I want to take it off . Is the ex brake worth the effort for my 93 ?
