Engine/Transmission (1998.5 - 2002) Pickup stalls after startup. Anyone have any advice?
Engine/Transmission (1998.5 - 2002) Wireing a 97s TPS
2nd Gen Non-Engine/Transmission 2000-2001 wheel ?
My pickup will start up every time but most of the time after sitting for several hours it will stall on first acceleration. Then it will start up with no problems. I had a mechanic tell me it was most likely a TPS which I replaced and it still does the same thing. I do have a fuel presser guage in the cab and I did notice that when it stalls it the fuel pressure goes to zero and then comes right back up to about 17-18 psi befor I restart. Any ideas?
More Info ????????
. truck ? YEAR ? ADD ONS ? I see this is your first post welcome to tdr . My advise is run these guy will drag you and your wallet into a pit of black smoke :-laf :-laf :-laf :-laf
But you will get there faster .
1998. 5 2500 quad cab 4X4 automatic currently running all stock except the injector pump I replaced last summer with the pump for the 245 hp HO also replaced the lift pump at that time and installed fuel pressure guage in cab.
did a search maybe vp 44 not sure i am not much help on this problem . was this a new or used vp 44 ? i am not sure how to read codes on 98. 5 . maybe some one will chime in
