Details here: TDR Privileges
Here's mine. I also have a fuel pressure gauge over beside the stereo (not pictured).
Small switch under the tweeter will shut the lights off on the gauges. You can also see the single screw I used to hold the replacement A-pillar on. It is very secure.
I used VDO because they match the factory guages pretty well, I'm waiting for my FP guage along with the new Guageworks column pod... . That'll hold me 'till I get bite by the Bombing critter again... ... ...
CCahill, what are your gauges from top to bottom, and what is the range on each (psi, EGT, etc. ).
You must be pretty stuck on your truck to be out shooting pictures of it when someone just yards away is facing impending doom. Why kind of guy are you anyway?? LOL
They are stocked by D. I. S. (in the links) and was easy to install. All wires, etc run up the left side of the dash the same as the Pillar mounts. It has velcro on the bottom to keep it from moving, etc. If I ever decide to go with the Pillar mounts it would be easy to change. I like it better myself. JMO
