Deezul1,
I have the whole shootin match apart right now.
The AFC is completely apart and seems to be fine.
I changed the AFC spring to the lightest one. It starts to open around 6 PSI and fully opens about 25.
I have replaced the overflow valve last week and I have the fuel pressure adapter from Mark at TST. It reads great fuel pressure at idle and up to 3000 rpm.
I just tonight replaced the fuel filter and cleaned the prefilter screen out.
Both of them had very low miles and the prefilter was very clean inside.
One thing I did notice was the fuel filter was in two seperate pieces and this was not the same as the one I replaced it with. The one I replaced it with was a single piece unit. NOt sure what that is all about.
Further, I just broke the rear cover off the pump to see about adjusting the governor position on the cam plate. As far as I can tell, it is fine as well.
I am going to reassemble the whole thing tonight and see if the fuel shut off solenoid is working properly.
If it is fine, I am at a loss as to what may be wrong. It runs strong until about 2000 rpm and the power falls off fast.
It feels stock
The only other possibility is the cam lobe for the lift pump is worn
I hope not!!!
Oh yeah, the lift pump is nearly new, maybe six months old.
HELP!!!!
Don~
