Finally installed Piers new "external" wastegate, to compliment the new HX-50 hybrid turbo. This is a neat modification of the ATS 3-pc manifold, which incorporates a riser on top of the exhaust flange of the manifold. This is not a spacer, it is a fabricated machined riser which the external wastegate is attached. The advantage is, unlike other external wastegates, it doesn't interfere with the position of the turbo and the exhaust down pipe. It can be used with any of Piers non-wastegated turbos, or wastegated turbos if inclined. The external wastegate is spring loaded, and with the right spring combination, can be easily adjusted to open at the appropriate drive pressure for the turbo you are running. The one on my truck is set to open at 48PSI and fully open at 56PSI. . i
