Engine/Transmission (1998.5 - 2002) Piers Street/strip Twins Installed
Engine/Transmission (1994 - 1998) Oil in #1 cylinder
Engine/Transmission (1998.5 - 2002) 5spd gone south
BWillard said:
Is this wrong way to do this??
matt says put it between the tank and pump but as long as you have the valve and pump activating at the same time i wouldn't see a problem with it like you have it.
i'd say call matt and let us know what he thinks.
another thread gone off topic :eek: my fault though,,,i brought the water/meth concern up !!
BWillard said:
Is this wrong way
probably best to ask matt. i do see that the label on the electric valve says 60 psi max. our pumps are running quite a bit higher than 60psi.
i put the plastic check valve between the tank and pump while i was waiting on a new elec. valve to be sent and have had no problems with gravity feeding. i may just leave it as is and not installed the elec. valve. did the same on my brothers psd with no gravity feed issues either.
back to the thread topic:
PDR TWINS are SCHWEEEEEEEEEET !!!!!
OOPS!! electric valve reads "150" psi max
