Pillar Mount / Gauge Source
24V injector removal tool needed
engine cleaner recommendation ?
I've been thinking about installing a boost gauge, EGT gauge and maybe a transmission temp gauge in my 2001 Ram. I would want a pillar mount w/tweeter. Any suggestions on a good source or sources?
Thanks,
2001. 5 Intense Blue 2500 QC, SLT, 5. 9L 24v Cummins, 4x2 Auto, 3. 54/LSD, 155 inch WB, Agate, Trailer Tow Group, Sliding Rear Window, Line-X over the rail, Leer Cab Height Topper.
<font color=blue>First off you need to decide which gauges you want. Then we can help you with a source. There are Autometers, Isspros, SPA Digitals, Wastach, and others I know I am forgeting. Once you decide then we can tell you were you need to get them from #ad
I'm open for suggestions. I'm afraid I have a serious shortage of gauge brand knowledge.
Thanks,
Bought gauges and latter found out some come with warning lights to alert you that you are approaching max EGR. Would have liked to have had that info before I installed the cheaper ones. Stephen in Sanger
I'm with ram boat, I would like to install a egt and boost gauge. I would like to put them on the piller but would like to take the old one off and install the new one. Don't wont to cut up the piller to install the two gauge piller. and now the dumb question, what is a tweeter.
Dirt Water Fox
[This message has been edited by Joe Kilburn (edited 09-21-2000). ]
With the 6-speaker stereo (newer SLT+ or selected audio option) there are small tweeters (speakers) installed as part of the A columns. The tweeter mounts are molded into the plastic A column trim pieces.
