The hole in the flywheel is straight through with no shoulder. I have used a socket and hammer to press the bearing out. You can replace it with a stock bearing or with a bronze bushing having 1” OD and . 75” ID, about 1” long. It is best to use new flywheel bolts from Cummins, part number 3901395, with blue Loctite. Re-use the flat washers with the more rounded side toward the bolt, and torque to 101 ft-lb. Have the mating surfaces on the flywheel to crank clean and dry.
