My 98 has a leaking pinion seal (dana 60). The pinion bearing will need to be changed as I can move the yoke up/down and side to side. There is play not much but enough that it will leak if I only change the seal. Has anyone changed this bearing. Can the bearing be changed, reuse any shims, and not have to be concerned with pinion depth?
