Started a noise like an air chisel in the drive line of the Ole Dodge.
I found a wheel bearing I had installed 2000 miles ago had a flat spot (installation error) but when I got the axle out it had shavings on the end of it. I took that as a grim sign and popped the new PML cover (also installed with the bearings) and found one entire tooth laying in the bottom on the housing. Trashed my $60 of new synthetic fluid... .
SO... ... Does this D70 need a standard D70 ring and pinion or does it need one that gives attention to the tone ring?
Also, Since i'm here, What traction aid to you guys like? Any of the Eaton stuff? Selectable lockers, Electric lockers?? I've got about $1,000 to play with on this so I wanted some suggstions from those of you running aftermarket traction aides (and yes, i'm aware it's already an LSD)
I just can't get ahead of the factory stuff failing..... atleast I know it'll be stronger in the end.
Thanks
Thanks
