We have 3 stoves 2 like the top pic in the upper part of the house 1 in the living room and 1 by the bedrooms. Both if not regulated properly will RUN YOU OUT OF THE HOUSE we have the one in the living room on most of the day and evening then turn up the one by the bedrooms and turn the other down. The other is in the rec room downstairs. The house is a little over 2K sq ft 1st floor. The amount of pellets is kinda hard to figure because how hot or cold do you like it? The Info below is kind of high I think we dont use as much as that. But then we like a cool bedroom and use covers to keep warm and same in the living room we use afghans to cover our legs while reading or watching TV. The use of ceiling fans distributes the heat REALLY NICE and have no cold spots in the house. I really dont know the amount we use because the lumber yard in town makes the pellets and we buy them by the TON. I will ask the wife how many times she fills ours up a week . Soft wood pellets burn longer and hotter than hard wood pellets
dont ask me they just do and it's a noticeable difference, We like them alot and would not go to wood stove .
Wood Pellet Stoves By the numbers
Freestanding models can heat from 1,000-to-3,000 sq. ft.
Burns about 15% more efficiently than wood stoves
Uses less electricity than four 100-watt light bulbs even on the “high” setting
Pellets contain about 15%-50% less moisture than wood
A 40-lb bag can provide 20 hours of non-stop heat
Some hoppers can hold 240 lbs of pellets
One ton of pellets equals 2. 8 barrels of oil
