Engine/Transmission (1994 - 1998) Piston, Cam Choices?
Engine/Transmission (1994 - 1998) head gasket coolant leak
2nd Gen Non-Engine/Transmission Hood Liner
I called woodruff diesel and talked to Doug west he suggested their 2V piston kit with the total seal piston ring upgrade he said that they have a bigger bowl.
I read some posts about the 370 marine pistons witch I am also considering I know they lower compression a good amount
I also don’t know to go with eater the helix 2 or 3 some posts say that the 3 is streetable and some say it is not :confused:
Any suggestions and or experiences would be great!!
Matt
Also I have a stock 94 12-valve engine for sale
What is a 2V piston? The sealed power gapless second ring is a great way to go. The marine piston will drop compression, but going with a stock-thickness head gasket should help.
The question to ask is how much HP are you going after, and how good of a daily driver does it need to be? From the sounds of it the Helix 2 is probably what you want. One way to help make it all come together is do some decent head porting.
