Engine/Transmission (1994 - 1998) Piston clearance
Engine/Transmission (1994 - 1998) Odd stalling problem
Engine/Transmission (1998.5 - 2002) Lift Pump Decision
Does anyone have a side-view picture of a piston? The reason I ask is that I pulled the head off this evening to replace the head gasket, and looking down the bore, I can see down in between the piston and the bore (to the top ring or a step in the piston). I know the pistons can't be sized that small or worn that much, so I'm wondering what's up with that?
EC
Keep in mind that alluminum expands at a different rate than steel, so the gap is most likely smaller once things are at operating temp.
