I got a trip coming up in a few months that involves towing a 10k trailer from PA to Moab. The truck is fairly stock as you can see in the sig... I'll probably be pushing the 20k GCVW of the truck and trailer.
I have the option to run either a 245 or a 265 tire... the shorter tire will hinder ground speed; but probably would tow better, keeping the RPMs up in 6th... keep in mind the truck has the NV5600 and 4. 10 rears. I actually have two sets of 245s and three sets of 265s... so getting the tires is not an issue.
I figure I have about 5 hard pull between here and there... Somerset, WV/OH line, MO, and CO... obviously CO will be the worst one. Now, I pulled the M37 home and travelled much of the same roads... didn't have to much trouble for a 215HP slushbox, but didn't even get close to CO...
If it were you, which tire would you choose? I'm thinking the 245s would be the better choice... probably not much difference in mileage between the two towing that much weight and it's not like I'm trying to set a land-speed record... thoughts?
steved
steved
