I am in the planning stages for a trip west from Northwestern Pennsylvania in the summer of 2015. Route will be out to South Dakota, Montana, Wyoming, and back. Idea is to see the Badlands in South Dakota, Black Hills, Devil's Tower, Yellowstone, Grand Teton, and then return - a little over seven weeks. I have the campground reservations made. I am working my way through many other thoughts now. Some questions for those with more experience than this newby:
(1) I see that there are route "guidebooks": the Next Exit, the Good Sam RV Road Atlas, the Mountain directory, etc. Knowing when the next rest area is (we usually stop and eat lunch at a rest area), where the next station is that one can easily get around in to get fuel, etc., seems invaluable to me. What are others using - what have you found best, what do you recommend?
(2) What are others using for emergency road service - do you use one of the Good Sam offerings, do you use another plan, what have you found is best?
(3) I have blocking, a jack, safety triangles and flares, and 12V air compressor. I have a four foot 3/4" drive breaker bar, extensions, and sockets for lug nuts, as well as a 3/4" drive torque wrench for reinstallation. I have put together a couple of bags of tools should something go wrong with the travel trailer. What other "emergency tools" do you think I should carry?
There will be emergency gear in the travel trailer - hydration packs, water filtration, emergency food, first aid supplies, water, fire starting kit, etc. A emergency satellite beacon will be along (we take it for hiking).
Cell phones will be along. I wonder about a NOAA weather radio.
Would you recommend any other type of emergency gear based on your experience?
(4) Prior to the trip, will do the following maintenance (most before due, but nonetheless):
Wheel/Tire balanced
Front and rear differential fluid change
Transmission fluid change
Oil and filter change
Fuel filter change
Air filter change
Grease front u-joint
The truck will have less than 25,000 miles, and so assume coolant, hoses, belts, and batteries OK.
Am I missing anything?
Thanks much!
Wheel/Tire balanced
Fuel filter change
Air filter change
Thanks much!
