SSolderitch
My oem liners were removed by the previous owner. I have since got a used set. I also got just the flat verticle plastic fill piece used on earler trucks. the 2 are mounted to the backside of the wheel. I noticed that they can also be used on the front side of the wheelwell. So with living in a snow/salt area, is it better to use the 4 piece setup rather than the full tubs? I notices some trucks with tubs rusting over the rear tires. Was it caused by dirt & rubbing of the liners? I have no problem removing them for a spring cleaning. Any thoughts which setup would be better?
