Engine/Transmission (1994 - 1998) Plate or Injectors
2nd Gen Non-Engine/Transmission Questions on rear leaf springs
2nd Gen Non-Engine/Transmission Oversize tire sizes?
I haven't had a chance to re-dyno yet. I will. I'm thinking 360hp. I'd like to get a gov spring kit first, but I want to go twins..... since I'm gonna have to O-ring the head, I may as well change the valve springs so I can run a 4k GSK..... No valve springs, no 4k kit..... humm... . choices..... I don't wanna buy parts 2 times.....
Josh
:--) I've seen so much info, but im still not sure about the upgrades. My truck is a 1996 12V california model EGR 160/400, auto with 4. 10 gears. So far I have replaced the trans with a pro-loc 47RE and conv. and have had the pump tuned, also K&N air filter. But as Tim Allen said "More Power!" Im looking at the TST #5 and AFC spring kit, then injectors also installing E-brake, as I tow a 5th wheel trailer 13,500 GVW. As pending install of gauges. :confused:
Originally posted by sgtpresto1
:--) I've seen so much info, but im still not sure about the upgrades. My truck is a 1996 12V california model EGR 160/400, :
Lose the egr, it corks up your intake, besides pumping hot sooty air back into your engine.
Mine was a 180 Cali engine, put a normal intake on, 300 hp injectors, 16 housing, #5 TST,16 degrees timing, jumped 4 mpg, almost zero smoke. Dynoed 302hp.
I should have left it there, it would have saved me thousands... ... .
