plowin'
Wet behind the doors...
Dana 70 question
if youd send it anyways I can probly figure out a way to make it work, i have like 6-8 inches between my pulley and the fan so If youd send it up to me that would be cool cause a couple friends I have andI can make it work. thanks
chainsaw
emptied my mail box 2!!!
f. boyle
Tried to PM you yesterday and your box was full again. Friday I couldn't get the fan off of the pulley, cause there is no room for my fan wrench to fit in there, so I took the whole thing (mount, serpentine & regular pulley & fan) off to send it to you. I went to pull the other set off my spare 89 motor and noticed the difference, it will not line up with any of the other pulleys on my 92. While I was waiting to hear from you, work called me and notified me that I had to work the weekend. I waited as long as I could, but I had to put my truck back together for work. Sunday as I was leaving work, I was told starting Monday we would be switching to 6/12 hour shifts a week, till further notice (busy time of year for us). With this schedule and no spare fan that will fit my truck, I wont be able to help you with this pulley, I'm very sorry to stand you up like this.
Paychk
Its all good! but now I have the question of : does anybody have a cheap place to get an electric hydraulic pump? or a way to get a 2 loop to run a 3 loop system (loop isn't the right word but I cant think of it so that works) left, right, and up. all cylinders are fed by a single line, and gravity reverse. I have a pump that has 2 outlets but I cant figure out how to either turn the plow the other way or raise it. any ideas will be helpful. thanks all, esp. paycheck.
Chainsaw
on my current plow truck I use an electric pump off of a hydraulic tailgate, it was only designed for power up and gravity down, I have that feeding the Fisher up/ down/left right valve body. I use a switch mounted to the joystick to power the solenoid driving the pump, I also had to plumb the return from the plow control valve block into the vent /fill port on the reservoir, works great.
sounds good to me!!! think I might just drop the whole plow idea. can't see beeting on my truck for the next few months is going to help me get to arizona to quikly. ya know. actualy been thinking of changing it to a 2 wheel drive. any helpful tips? are thes trucks solid frond axle or ifs 2wd? any one want to trade parts? all work great. what other than the axles do I have to change??
Chainsaw
Looking back I should of stuck with the plow and vermont!!!!!!!!
