Details here: TDR Privileges
Can this code keep eng. from running? Just put Edge Comp on and it was running fine then it just quit. Scaned it and this is the only code PO237 MAP sensor voltage too low.
Cleaning the connectors Wont help. the comp box is probably BAD and you've fried the pump.
I'm guessing if you crank on it for a while or give it a shot of ether it will start. and run ok . then when you restart in less than 5 minutes it starts ok. longer than that and you crank for a while. as if you have a No fuel condition.
No other symptoms. Just hooked up comp drove about 100 miles everything working good, parked then was heading to a friends just quit running it will crank but will not fire. Disconected the comp still nothing
