POD's where to buy them
Here' a pic of nascar marks moose...
1'st Gen at Diesel Thunder
Need a contact phone number for where to acquire them.
Also, to get the total benefit, do I need to go to the smaller turbo housing?
62 MaxWedge,
Before you add injectors or any upgrade in power, install a boost gauge and pyrometer. This is a most invaluable source in determining your engines functions. You have to keep in touch this way with the operating temperatures etz. Its like driving a vechicle without a speedometer.
Chuck Goode
Ouch! my mistake Eric. Did not read your signature good enough.
Have fun.
Chuck
For the injectors, I would go with Piers. The reason I say this is, he has the best warranty program around. If you are running a 18. 5 housing, I would concider a 16. It may not give you an imediate power increase but over time it will allow you to run cleaner and improve milage. PODs need lots of boost to run clean.
If you haven't already done it, I would go with a better exhaust system and a better intake. This will allow you to get the full benifit from the larger injectors.
I noticed you have your timing turned up. How far? This will also help with smoke and throttle responce.
Good luck and have fun with the bombing.
Dave
