Pokeing thru!
96 Lift Pump part # ???
Rebuilding a cummin?
I installed a cb in the ram tonight and found a great place to "poke" wires thru the firewall. If you have an auto trans there is a rubber plug where the clutch linkage would go thru the firewall. There is about an inch and a half hole that you could poke wires,boost lines,egt wires thru!!!:)
Speed Baby ... ..... Speed (installing anyways)#ad
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff#ad
N. E. T. D. P
Thanks for the tip HTRDHLR. It's good from time to time to bring up old topics such as this for the benefit of newer members.
Me? It's a good thing I do have an auto. equipped Ram... with the number of wires/sheathing I have running through BOTH firewall grommets, I'm just about maxed out. :D
TIM
It does not matter what you do to it or what transmission you have behind it these trucks will never be FAST. They will jump off the line up to the limiter but I do not consider 112 +/- to be fast. ;) May be you should switch over to the rice world or just stick to that motorcycle of yours. :D :D
Originally posted by Ted Constantine
TIM
It does not matter what you do to it or what transmission you have behind it these trucks will never be FAST. . :D :D
Thanks for pointing out my oops TED. I forgot to add the sidebar grin of installation but was too horny on cutn' and pastin'.
That was not how it was supposed to sound . As for rice ..... [ching~ca~da~ding~ding~dang~ding] ouch [/chinging]
Sorry Tim I was a little fiesty. Just rassing you for the three pedal members of society;) Time to learn how to use your monster smiles.
On a different note, I sure do miss the days of having that big hole in the fire wall to run wires. The electrical grommit is defintely maxed out :rolleyes:
Ted
I love that big 'ol grommet (*sigh*) between my guages , FMC , Smart controller , Piaa's , 2Gua amp feed , compressor control , and many others that has been a sure~fire speedy way to do things!!
