In an effort to try and include everything that was said to missing from the original injector poll, I have redone the poll to show the entire fuel system from the lift pump to the fuel filter to the CP3 pump to the injectors, included is warranty voided, stock, box/programmer, 600/610 engine, 555 engine, injector failure, lift pump failure, CP3 pump failure and fuel filter problem.
Please keep in mind that the polls only allow up to 10 choices, so I did not include trucks with no failures, we are interested in the failures not the ones that have not failed.
In your text response you may state that you have a truck with no failures and everyone can also state if they used a fuel additive like Power Service, Sea Foam, ect.
Please remember to select if your truck is stock or has a box/programmer and which engine you have.
