What's happening is that when at a stop or traveling at low speed, the fan clutch doesn't speed up the fan when the a/c is on. This causes the compressor to kick off and on because the condensor isn't being cooled. The cooling inside the cab is poor at best in this situation. I've sat and listened to or watched the fan on a few occasions, like today, to see what it does. The fan will run at slow speed, like barely 200 rpm, for a good minute or two, then it speeds up for about 15 seconds. If I'm inside the cab I can tell when the fan is coming on/off because the air temp will drop and then go back up again. Coolant temp doesn't seem to have any effect on this behaviour. I've read about a similar situation on the '03s, but not on '05s Maybe there's a TSB?
Sean
Sean
