There is a place for every modification on a diesel. Port work is HP that is free in a sense, that it doesn’t have a down side, like a bigger turbo or huge By making the ports flow more, you reduce the restriction in the intake tract, the pressure goes down and the air is able to get past the valve and in to the motor, cam timing is a similar deal, open the valve higher and longer you get more in. the 130 lbs of boost that a few claim is just factor of improper cam timing and restriction. If you really work you head program, that boost will be down to under a 100. with some of the head work possible with a full on head program you could get that same amount of air in the motor at less them 50 lbs of boost . I would not rule out port work and a good cam for a mild street truck
