Bob--sounds good to me. I hope your shoulder's okay!
I didn't have a lot of light to work with outside tonight, so I just took the truck for a test drive to see how things went. The pressure stayed solid at 15-16 psi the whole time. It cranked for quite awhile before firing, but I think that was just because I'd had the line off the FASS and got some air in there. I drove about 5 miles and the engine ran perfectly, no burps or hiccups whatsoever. I'm starting to wonder if I just had a clogged filter from a bad tank of fuel or something.
I checked to see how we'd plumbed the fuel return, and it's teed into the filler neck vent, but way down by the tank. Given that it's so far from the filler cap, I'm actually kind of surprised that I was able to see any fuel come out at all up there.
One question I have for you guys familiar with the electrical pressure gauges--this new one I have seems to bounce 1 or 2 psi all the time, and I'm worried that this is due to pressure spikes that I've read are so harmful to the sender. I'd thought that by mounting the sender to the grease gun hose (with a bunch of air in it), and then into the tee in the fuel line, that it would help cushion the sender a little bit. Is there something else I should do here to protect my sender?
Mike
Mike
