I had a problem a few weeks back, where my truck would crank but not fire. This is a 1998 12v CTD with the manual transmission. Before I had any issues, I was getting 16-17mpg. The first fill-up after the problem started, I was at 13mpg, and have been at a steady 15mpg in the month after that.
Now when I start the truck for the first time each day, I have to give it a few seconds on the throttle for the engine to fire.
I took some time to play under the truck today, and noticed the drivers side frame under the cab was wet and smelled like diesel. There has also been a bigger drip spot under the cab when I park.
I'm assuming there is either a busted fuel line, or a loose connection between two lines. What is my next step to find out what is wrong and fix the problem?
