Possible Gear Clash Solution for 3rd
Just switched to a 24 valve, now what?
Hard starting
Alan Reagan
I had a slight 3rd gear clash until I seated my clutch pulling down a large dead pine tree. It had all but disappeared but I would get an occasional rub when accelerating to merge into traffic. I noticed that when shifting with this very straight shifter I tend to shift into third at a slight angle to the right. If I shift straight up (which feels like a slight movement to the left) I get no clash even under acceleration. In other words I was shifting with pressure towards the radio display. If I shift toward the volume/tuner knobs, no clash and easier shifting. So I looked at the shifter some more and sure enough, the shift towards the knobs although seeming to be a little to the left is straight up #ad
. Somebody else with a six speed and clash want to try this and see if it works. Now that I've shifted this way for a while I don't really notice it. What made me think about it was a ten speed
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards, Lucerix X Mount Heated/Power Mirrors
Do you drive a big truck like an 18-wheeler?
If so remember your schooling days that they told you to preload with the palm of your hand to push into gear and not "grab" it with the whole hand? I have found on my 6 speed that if I do this, I have not had a clash at all but once in a while I grab it and I clash so that is the secret but if what you do works then don't fix it lol
Eric
2001 QC 2500 4x4 bronze W/two tone Driftwood, 24valve HO 6sp. Blue chip 4-wire box, mag hytec dif. cover, BD stage 1 injectors. Westin side bars, fender flares, Rancho RSX off-road shocks, Spray on bedliner, sweet tooth grill, Leer shell Painted to match with LED marker lights, Bf Goodrich AT Tires. Bed rug inside shell W/aux marine deep cycle batt for lights, etc. M Brolins' CB mount.
Name of rig is "big bronze Brute"
I used to drive the big trucks and that's what made me think of this. You are correct, now that I'm doing this slight jog to the left, I am using the palm of my hand to feel the detent/shift. It's like an optical allusion..... that very straight stick makes me want to "push" up which is to the right of where the correct shift is. I got it now though.
My last truck was 1970 350 4x4 w/granny low first. I called it the mystery shifter. If you hit the pattern right, ya-who! If you missed it would just bounce off the gate.
Great trainer for the six speed!
2001. 5 2500 ETH/DEE 4x4,Patriot Blue over Silver,Camper pkg, Trailerpkg,3. 54LSD, Agate Leather,Stainless Smitty Bars,Tow hooks,Amsoil,Window Fix... ... ... :) Born on 5/19/00
