Originally posted by Sky
Is there anyway I can "fill my post turbo tap" and then tap preturbo?
Originally posted by HC
Don't plug it - keep your post turbo temp, too. It is the one that is more accurate for telling when to shut down. The old threads discuss the whys...
Originally posted by Cooker
KAT,
I thought you's know better. He doesn't need a new gauge just a new thermocouple and a DPDT switch. Depending on the brand thermocouples can be as low as $35.
I agree to have pre and post probes is the best of both worlds.
-Ryan
KAT,
-Ryan
Kat, yes I am very seriously considering getting piers turbo, i talked to him at Timberline in Saturday. But I am not sure I need it yet. I drove Joes truck (TDR name 24valve dsl) He has the same set up as me except he has dd2's and the hy35 modified a little to where he can see about 28 lbs of boost, I get 20 max. Oh and he has a RE0880 K&N, I have a Stock box K&N. So anyway his truck cools way faster then mine does. He just sits and waits maby 10-20 seconds at the most to cool and mine takes a good min. So im trying to figure out why he is getting so much cooler then i am with the dd2's and I have the 275's. Does the RE0880 make the difference, or is it the dd2's that do it? Or is it the differnt muffler for the exhaust he uses. I am guessing its a mix of all the above. I would hate to spend around $1000 for a new turbo and can get away with useing mine. I think what I need to do is get a preturbo reading and then maby upgrade the other stuff and leave the turbo till last to see if I really need it.
I order the RE-0880 today so that may help. I think I would like to try that switch thing to show both pre and post turbo. Does anyone know exactly what I need to do this with the Autometer ultra lights? Any help or part numbers would be great! If I dont go that route then I will move it to pre turbo. I will look up that spring deal, but remeber I have a limited amount of mechanical skills (unfortunatly).
I do have a question though, If Im not at max boost then my egt's wont matter what turbo I have correct?? What I mean is if I get a max now of 20-21 then if im at 15 going up a hill and I am at say 1300 degrees Pre turbo ( I know its not likely) then as long as my boost isnt maxed then I wouldnt matter what turbo I had on right, the egts would be the same as long as it wasnt maxed out?? Or am I way off on this? Im still educating my self here so bare with me.
Mike
