Powder Coating
VDO guages are stealthy...look like original
CB Antenna Mounts
I am getting the bug to put dual stacks on the truck. But I'm not sure about the chrome stacks, I thought about black set instead. I was wonder if I could have some heavy walled pipe (4" or 5") powder coated black and would it handle the heat?
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, Pre-Turbo ISSPRO 3" Pyrometer & Boost Guage,Silencer Ring Removed
15,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks,Amsoil Dealer,Straight Piped
Where I really wanted the coating would be from the time that it goes thru the bed on to the end.
The truck is a maroon color and it looks alot better with black parts instead of the chrome. Also with the heavy wall stuff, I am thinking it would have a real nice sound.
Rick
RICK
Rick,just read your thread,I finished my stacks yesterday,I ran from stock 3''down pipe to 3x4x4 tee/wye and up with twin 4''no res or muff,it is pretty loud,I may put the stock res back on before wye since it goes from 3 to 4''. I got all stuff at a truck place here in s/j ca. I got aluminized steel 10'piece $45 ells about $24 each and special s/s clamps where flex slides over pipe,because s/s flex and 4'' pipe have different o-dimensions. I have a powder coat shop on same sreet as my shop,he said he could do both for $100. I am considering a clear coat over powder to make it with stand the heat better. The welding of aluminized steel was a snap [mig with gas]any questions feel free to e-mail. good luck,JDM JOE
The powder coat will burn off probably 2-3ft from the turbo. After that (esp. with a flex elbow) it should last awhile. You can get black Jet Hot done for $10/ft and that will last for ever.
2001. 5 ETH/DEE 2500 4x4 3. 54 lsd, Autometer Boost & EGT. 33' Weekend Warrior 5er and an army of toys to fill it!
'96 1500 360 3. 90 LSD 3" cat back no muffler! 110,000 and still eating chebbys for lunch!
Have used parts that have been Jet Hot coated. Real nice stuff, your stacks would look great and last a LONG time if you had them done that way. My only question is, i have never heard them mention if it is affected buy UV light? Like, will the color fade? Give them a call and ask before you spend the money to have them coated.
01' Intense Blue 4x4 QC SB Auto, Black Leather, Camper/Tow package, etc, etc. JRE Exhaust, Psychotty, Autometer Sport Comp: Trans Temp, 0-35psi Boost and Pre Turbo EGT Gauges, Rhinoliner, PIAA 520 Fogs, Stull "Diamond wire" grill, Westin Stainless sidebars, Smity bilt "Outland Sport" stainless bumber guard, Hella B/U Lights, Tint, Pioneer audio, JL Audio 12" Sub in center seat. SEAL TITE crossover box. Amsoil dual bypass with the "CPFF" Adaptor and braided stainless lines, Husky liner mudflaps, Motorola Spectra Locomotive radio, Mag-Hytecs Soon.
I have signs I make powder coated often. There is different kinds of powder coat - some UV resistant and some heat resistant. Epoxy is the most durrable but will not take sunlight. Urathane will take sunlight, but not sure of heat. $100 seems way too high for 2 pipes, but that may be their minumum order.
Blake
"Blue Bomber" ... Blue & Silver 1995 2500 Laramie SLT, Regular cab, 4x4, a/t, K & N air cleaner, 16 cm turbo housing, 290 hp/700, 3. 54 LSD, 265-75/16 (for now). Steam Engineer and NRA Endowment member.
I powder coat most brackets, bike frames, K-frames, but for intake or exhaust parts I use the high heat coatings, you can get them in aluminum or black. They will be better than powder for exhaust componants.
I use AirBorn Coatings exclusivly, never a problem, always look great!
They have shops around the country East Hartford CT ph. #860-528-8281
good luck
96 3500 4x4 red/black waterfall paint, 370 inj. ,gov. sprg. ,K&N RE880,4" str. exhaust,pro torque conv. , trans-go shift kit,Alcoa Hotshot wheels,235/85/16,custom cap(it is a work truck you know)best ET before inj,exhaust, and gov. sprg. 16. 49@78@7700# soon to see what she'll turn now!
68 Charger R/T 432" Hemi, 4spd. ,street car no suspention mods, full interior,only changes from stock, glass hood and Centerline wheels. best et w/440-6pac 11. 55@125 I'll know how the Hemi runs June 3rd stay tuned
96 Grand Cherokee computer,str. exhaust,K&N ram air set up,Best ET 15. 2@88
79 H-D 115" Shovelhead 103horse/119ft/lb, motor went 9. 90 on drag frame we'll see what it does on a street bike soon!
Stock Sucks and yes I'll race anything!
