Power Accessory Option
DOR front bumper?
Intank LP retrofit
I went to the dealer this morning to have them turn on some options on the ECM. I asked them to turn on the High Idle option, the Fog light on with bright lights option and the Power Accessory option. The service writer wrote down everything I asked for. After a short wait he came and got me and said the High Idle was turned on but the other features I was wanting can only be done on 06 models and is not available in 05.
Does this sound right or is he shooting me a line? :-{}
By the way, High Idle option works great. :)
That's the first I've heard about the fogs on with the brights. I didn't know you could do it. If it does work someone let us know.
Randy
According to the mechanic at the dealer it is an option on the 06. I found out about it by reading the online instructions for a Bullydog Tripple Three. The accessory option leaves your accessories on until you open the door or it times out. the fog light option leaves the fog lights on during high beam. This is what I have been able to search out on the web. Ho ya, there is also a option for daytime running lights too. The mechanic said the only one available for the 05 is the high idle option. It works great.
I have the high idle and accessory, but this is the first I've heard of the high beam w/ fogs. I'll have to ask if that can be done on an 07.
Thanks,
Kyle
I don't know if it is the same on the newer trucks, but in mine all you have to do to leave the fogs on with the brights is to remove the foglight relay and place a jumper between pins #2 and #5. All the relay does on my truck is to turn the lights off when the brights come on. The pin numbers are from the smaller black relay, not the larger one with pins 85, 86 etc.
i want both of these for my 04. .
can future smarty upgrades do this???
Nick,
From what I understand the smarty can only do the High Idle option. Not sure if it can do this for the 04. I was really disappointed to find out I could do the accessory option on my 05.
It was my understanding that daytime running lights required an additional module to activate and was standard in Canada and required a wiring change for U. S. A. trucks??
Nope, third gens have the feature built in (at least through 05).
You just have to change the country code in the ECM to Mexico or Canada.
Scotty
High Idle: what is this? Is this the thing where you can set the idle with the cruise control?
Power Accessory: Most of my newer vehicles have done this. Oddly, I didn't even notice that my truck was not doing it! :)
Fog lights: "Allnew2Me", the relay trick works on my 01 Jeep, but not on these newer trucks. I'd really be surprised that this can be changed by the dealer in the computer. EVERY vehicle I've owned with factory fog lights since at least 1985 won't allow the brights and fogs to be on at the same time. I assume this is somehow federally mandated to the manufacturer's, so I'd be very surprised if it can be fixed with software changes and allowed by the manufacturer to be done by the dealer. I thought the only "fix" for this was the Bright Box which tricks the computer.
By law, you can't run the foglights and highbeams together, however you can run driving lights and highbeams together... ?
If they inspect your car in PA, they do check and if the foglights are hooked to the highbeams (or don't turn off when the highbeams are enabled), you fail inspection. And this is supposed to be federal, not state law. I know I have had friends pulled over and fined for it before too.
I know why you want it, but just a heads up and to keep in the back of your mind.
steved
I spoke to 2 different dealerships and they said that they had never heard of "turning on" the power accessory option. Neither place offered to look into for me, the only help I got was a suggestion to call Dodge. So, I called Dodge's 800 number and they looked up my truck and said it didn't come with that option.
Can anyone provide more information so I can provide it to the dealership and have them look into it for me. Thanks.
Bully Dog Triple Dog options
This is off BDTD's web site. I don't own one but just going by what I read.
Idle UpThis feature is only available for vehicles with an automatic transmission. When enabled this feature will increase the vehicle idle RPM using the cruise control button system to facilitate vehicle warm-up under cold weather conditions. To use this feature, enable the feature by pressing
the ‘Y’ button on the downloader. Once enabled, start the vehicle and follow these steps:
1. Using the cruise control button system on the steering wheel, press the “Cruise On” button. Watch to make sure
that the cruise light on the gauge system turns on.
2. Press the “Set Cruise” button located just below the “Cruise On” button. The idle rpm will instantly rise up to
1100 rpms.
3. Use the Accel and Decel buttons on the right side of the steering wheel to raise the idle rpm as high as 1500
hundred, and lower the idle rpm back down to 1100 rpm.
Auto Door Lock
Enabling this feature will cause all doors to lock once the vehicle reaches a speed of 15 mph. Then once the vehicle comes to a complete stop, if the driver’s door is the first to open all of the other doors will automatically unlock.
OUTLOOK INSTALLATION
Introduction Harness Description Operating Instructions Pyrometer Probe Calibration OutLook Installation Troubleshooting
Dodge 5. 9L Cummins Vehicle Specific Features
Head Lamp Delay
Use this feature to set the amount of time that the head lamps remain on after the vehicle has been turned off. Use the up/down arrows on the downloader to scroll in 5 second increments between 0 and 80 seconds.
Fog Lamp
Enabling this feature will allow the fog lights and high beams to operate at the same time. This feature is for Off-road use only.
Horn Chirp on Lock
Enabling this feature will sound a horn chirp each time the doors are locked when using a remote door lock system.
Optical Chirp on Lock
Enabling this feature will flash the hazard lights each time the doors are locked when using a remote door lock.
Seat Belt Minder Chime
Enabling this feature will remind the driver to buckle their seat belt with an audio chime each time the vehicle is put into drive and the driver’s seat belt is not buckled.
Accesory Delay
Use this feature to set the amount of time that the accessory items in the vehicle will remain on after the vehicle has been shut off as long as the doors remain closed. Accessory items include the radio, cigarette lighter, etc. Use the up/down scroll buttons on the downloader to choose between the following settings: 0 seconds, 45 seconds, 5 minutes, 10 minutes, 30 minutes, or 60 minutes.
Unlock Driver Door
Enabling this feature will affect the way the doors unlock when using a remote door lock. If enabled, the first time the remote unlock button is pressed only the driver door will unlock, the second hit will unlock the passenger doors. If disabled, all doors will unlock on the first press of
the remote unlock button.
Oo.
