I had a door lock go bad the other day. Did as search here and found a couple posts about them. Thought I would go and check for a busted wire like Bighammer found. Sure enough I found a wire broke in two. Two of the other small wires needed taped in bare spots. I guess you should not use the back doors they are there for decoration! I would like to replace the harness if the cost is not to bad.
