power edge ez
Flowmaster Gone!...Interesting results
brake master cylinder
I just ordered my power edge ez sunday,(with wife scowling at me in the corner). cant wait to install it. :D I read several posts about three different power settings on the ez, but power edge web site does not mention these. just curious if this is a one power level box or a variable one
Essentially it is a "one power level" box. The three settings you have heard about merely control at what boost level the addtional fuel is added. The same amount of fuel is added in all three settings, its just a matter of "When". It is mainly for smoke control, but also has a few other effects on fuel milage and what not.
Does that explain it? Or should I try again? :D
Search Engine
d bronec, since the PE EZ has been out for awhile you can find Pages of FAQ's using the TDR search engine.
The EZ is a great product. The settings that can be changed are for smoke control. It will usually come set for the "KWIKest" fueling curve. And if you have Bombed Injectors and want to cut down on the smoke at low boost levels then you can easily change the pin setting to the slowest curve. The Total HP gain should be the same.
