Power Edge Fueling Module
welder
What oil is best
Have installed the power edge and man what a prduct!!! Less than an hour to install and all the power I need(for now). I agree the customer service i recieved from Brett and Taylor was and is first class!!! Now I am looking for transmission and exhast upgrades, any suggestions see my thread in the 24v forum.
Again a great product from a great company.
I too want to learn of those cool graphics.
<font color=teal>bpete -
When I get home from work today I will forward you the same email I sent Mike Vonda in regards to the animation type stuff in posts.
Secondly, did you get my "other" email from last night? I got something "forwarded" from you last night but I couldn't read it... just wondering if you had replied to my first email or not. (Hope all this makes sense).
Mike V -
If you need more help email me and I will try to help ya figure it out. Best way to learn is trial and error! #ad
Me too Kat, Me too! Send me those instructions #ad
Just wanting to know if I need to order Edge's boost module or will the Power Edge be enough to wake up my stocker?
'99 2500HD Quad Cab 4x4,Intense Blue Pearlcoat,fully loaded w/Agate leather interior,5-speed,4. 10 limited slip,Skyjacker Leveling kit,Heckethorn Nitro 9000 shocks w/dual end to end steering stabilizers,35x12. 50x16. 5 BFG/AT KO's on 9. 75x16. 5 Eagle 589 Aluminum Wheels,9004 Cool Blue's,Silencer Ring removed,Fog Lights relay pulled,No muffler,No resonator,4" straight pipe.
[This message has been edited by WOWZY (edited 06-04-2000). ]
WOWZY - I sent the email. . also go read the other thread you have going asking about the PowerEdge. . I replied over there.
Wowzy, the Power Edge has integral boost signal control. You don't need a separate boost module.
I just got back from visiting "Willyslover" at the hospital and an overnight at my PSD neighbors place at Dodge Ridge ski resort. My fearless copilot on this orbit happend to be David_VT. I was interested in his feedback since he has knowlede of things electronic. We agree the size (1/2 of the blue box) is a plus. This device could fit in the ashtray if you were so inclined. The look is very good with the graphic on the face and non cotton candy color #ad
The power level is stout and the led display is a strong step up in function from the others in this market.
Kat,
If it's not too much trouble send those instructions for the animations to me too.
Don't ya know as soon as I spent some money on the Ram (again), this time for Grover horns, the Power Edge comes out. If I eat peanut butter sandwiches this month maybe I can get one next month... .
Of course that means that I'll be needing a new clutch too. the stock clutch is protesting the power I have now. go figure...
1999 2500 4x4 SLT QC Cummins ISB, 4" exhaust from turbo back, 5" chrome tip, TST re-flashed ECM, 275 hp. injectors ,NV 4500,
heavy duty transfer case,towing package, travel group ,Pricol boost and EGT gauges mounted on the piller
White/driftwood lower, camel interior, 12 DISK! cd changer mounted under the seat.
<font color=teal>MikeB and bpete -
I emailed you both instructions in the simplest way I know how to. I hope they help, and questions email me back with specific questions.
Installed my Power Edge on Saturday. What I've seen so far is pretty awesome. Couldn't do any serious runs due to the rain, but got to play a bit on my way into work this morning. Like I said, pretty awesome, and I've still got "Level 3" to check out. So far, I haven't seen any real smoke or worrysome egt's. So far, I'm very satisfied. I should also mention that Bret and Taylor at Edge Products have been great! - I encourage anyone with questions or concerns to give them a call. Ya know, I thought I'd cured myself of the dreaded "Bombitus", but I reckon I was only in remission.
I did a little testing of level 3 on the Power Edge yesterday. Good thing I am getting rid of the rear tires soon in favor of something a tad more robust. They break loose around the corners and it may be necessary to add a wing on the roof or put the steering wheel on the door #ad
Has anyone heard anything about Edges combo with the propane?
that price looks good, would that come with eveything I need to intall propane, less the tank. Or is there other accesories needed for the propane intall?
2001 3500 slt+ sport HO ETH 6spd every option available Black with agate leather
3:54,Class 5 hitch
HVAC,
In your testing of the PE, what configuration are you running? Is it DD Stg III & PE only or are you running one of the other boxes in conjuction?
Thanks.
The Power Edge plus comes with the Power Edge and all the hose and fittings to get your propane up and running. It includes the lock-off and regulator. You can get a glimpse of it if you go to my site and check out the pics. The regulator is under the conical air filter and attached to the fender. You will need a tank and bracket to secure the tank. I have a 8 gallon aluminum fork lift tank mounted in the bed. The Power Edge has a separate switch to arm the propane system. Just wire the module to the lock-off and the propane system will come on line at 3 psi boost. You don't want the propane system active at idle. Email me if you are interested in a competitive price.
Mark, you can see a profile of how my truck is set up if you go to my site and check out the fromt page. Click on one of the links I left above. I don't use the nitrous very often due to the expense. I have disconnected the Blue Box and the DD boost module as the Power Edge replaces those two devices.
BOMBs away! I just got off the phone with
Taylor at PowerEdge. Mine should be here
in a few days. Also have Auto Meter boost
and pyro gauges and an A-pillar mount coming
from Summit.
Gonna have to start looking out for these guys now!
Chris
'01 3500 QC 4x4 SLT, Dk. Garnet Red with tan interior.
ETC/5spd 3. 54 anti-spin,Line-X, Valentine 1, Kenwood
TM742 tri-band Ham Radio VHF/UHF/6M & GPS APRS Tracker N5CWM-2
I have been running the PowerEdge box on my ETH for almost a month now and can echo all the positive comments stated by everyone else previously. Brett and Taylor are knowlegable, honest, sincere and great to work with. They are also quite modest and don't toot their own horns much. I have toured thier operation and met their techincal staff and have come away quite impressed.
There are few observations I'd like to make concerning the PowerEdge.
1. To my knowledge, the PowerEdge is the only box wich is controlled by an actual CPU. The CPU constantly monitors what is going on with fuel, boost, timing, etc. This way custom fuel curves can be programed into the unit which permitt such things as gradual increases in the fuel dilervery which overcomes problems with the sudden surge of power and smoke associated with the Blue Box for example. Eventually it will also be able to control timing also. They are experimenting with tming to increase power and reduce EGTs.
2. Everything about the PowerEdge exudes quality. Nothing here looks like it's from Radio Shack. The case is extruded aluminum, not stampted. The connector which hocks to the to the fuel pump wire is a very good idea. They have run tests and it is able handle all the current for which the wire is rated and for extended periods of time. Best of all when removed, it's very difficult to tell if a wire has ever had the connector hocked to it.
3. The 3 power levels are selectable on the fly. They are also custum programable by Edge Products for what ever power levels anyone would want. If you like smoke, that 3rd level can be setup to make lots of it with stock injectors. I personally have tried 3 different sets of power levels and feel the out of the box settings fit my needs quite nicely.
4. An EGT guage is a must and in my opinion should be required with the use of any type of fueling device. During testing the EGTs of my ETH were reaching 1300 degrees at 32 to 33 lbs of boost, runnig empty on a flat stretch of road going very fast. That was with Brett driving. Personally, it's not a problem with me because I don't ever drive that fast myuself. I also find that backing out of the throttle to reduce temps isn't all that bad because even at partial throttle, with the PowerEdge enguaged, my truck is producing more power than at full throttle, stock. But if you're towing and or going up any long grades the pyro is a definate must.
4. Actual fuel mileage, if anything, has gone up after installation. I'm getting 18+ mpg with 90% in town driving and lots of hot rodding around. However, the trip computer is no longer very accurate and at my last fillup was reading 3 mpg better than what my truck was actually getting.
5. The propane option certainly looks of higher quality than the Bully Dog units I've seen. They tell me EGTs are a problem when running the propane and the power increases aren't as great as with the PowerEdge module by itself. But the increases are cumalative if a person wants to run both. Installation loks slick and simple. The PowerEdge box itself helps control the propane and physically looks the same as the regular box with the addition of another button and light on the right hand side. Both Brett and Taylor are running propane on their trucks out of one of those 11 lb Hyster propane tanks located in the bed. They tell me one propane tankfull last two diesel tankfulls. They say the part which bothers them the most is the hassle of having to fill the propane bottle every other diesel fillup.
5. If you're running an ETH then I recommend you seriuosly look at this product because when it's turned off you'll swear a third of your engine has quit working. Turning the unit on during acceleration definately makes a big difference - like kicking an automatic down into passing gear.
'01 ETH/DEE
trailer tow group
camper special group
354 posi
PowerEdge module
pilar mounted combo pyro & boost guage
HVAC,
The check is going in the mail box first thing in the AM. Then you will be able to find me sitting on the front porch waiting.
01 2500 SLT+ QC LWB 4x4 Auto 3. 54 rear end Forrest Green Sport with all options avail
DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner and Leer 160XL Topper
Soon to be Power Edged. Gauges and 4" Exhaust in planning stages. Dreaming of transmission
up grades and injectors... ... and some type of Airbox mods.
See My Truck
2000 Skidoo Summit 700
