2nd Gen Non-Engine/Transmission Power-heated Towing mirrors for '94 - '06 upgrades
I just installed a set of Kool-Vue power heated towing mirrors on my '96. I've tried to put all the information, schematics, part numbers, wiring diagrams, and what to do information on my web site: Dodge Ram - Towing Mirror Upgrade Information - '94 to '06
That's better than having to go through 200 postings to get the information. If folks have suggestions, email me and I'll update my web page.
This includes links to earlier TDR threads, and to a good source for the mirrors.
Good info, Charlie. The one thing I noticed is that there is no foam gasket in the diagram. I would suggest that is also a necessary part, to keep everything sealed up. Anyone know if that part is sold seperately and, if so, what the part # is?
Heh. I left that out of mine, and now have a wind whistle.
I need to pry the top corner of the door panels back off, I think I can stuff the original foam glob back into the inside ... maybe with a little carving job. After I put these back in, I'll update the web page.
The Kool-Vue mirrors come with a 1/8" thick foam gasket that goes on the outside, similar to what I called the rubber pad on the parts diagram.
The web page should stay put at the same URL, that server has a lot of autmotive stuff on it.
Haven't done it completely yet. I ran wires from the 2 black wires, through the door wiring tubing to the under dash area. I connected the wires from both mirrors together, and grounded one wire. The other one will be connected to +12 through a Radio Shack relay and a 10A inline fuse. The relay will be energised (to turn on mirror heat) with an illuminated rocker switch - so that the switch is lit up when the mirror heat is on.
I have updated the web page Dodge Ram - Towing Mirror Upgrade Information- '94 to '06, there are now pictures of my '96 with the mirrors folded and flipped up. There are also pictures of the '94-'97 3 wire connector showing which wire does what, and describing how to wire the 3 wire to 6 wire conversion.
