illflem,
I hear what your saying, but how do you think the hot fuel is playing into the picture? In order for it to behave the way it is it must be: Rack unable to rotate plungers (for whatever reason), Air in fuel (reducing the actual amount of fuel injected) or restriction in fuel flow downstream of gage. I don't see where hot fuel, in and of itself would cause a power loss other than due to reduced density because of expansion, which is not too great. If I remember right, #2 cracks down around 460F. Up to that temp, it is pretty stable. I doubt if it is hot enough in the tank to cause a heat related problem with the pump or injectors. The injector tips surely don't run that hot.
I am looking at it from the fundementals that it is loss of fuel injected into the cylinder causing the problem. Are there any other things that can cause these symptoms?
A truck in good condition that is shut off and re-started will fire on the 1st or 2nd piston to go over on compression, especially with a small amount of accelerator input. If this truck actually cranks a second or two before starting, then the problem is still present, but the system is able to deliver the idle quantity of fuel to get it running and make it seem normal.
The fact that throttle position has no effect seems to indicate it is starving for fuel, or so much air entrained it can't pump much fuel.
What is EGT and Boost doing when this happens?
One other question. For those with fuel pressure gages. When you shutdown how slow or fast does the pressure bleed down when you turn off the key? How does that compare with the shutdown of the problem child?
Sorry, one more question, if anyone knows. What happens if the overflow is blocked all together on the P7100? On some pumps this creates problems with air in the pump. Fuel can cavitate some as it enters the barrels and in some pumps it is REQUIRED to flow fuel through to keep it clean of "air". That is the foaming we see when we use sight glasses.
Keep this thread going, I want to know what is really going on!!
