Which my scanner was working to save me all this typing. In my 2001 Service Manual Supplement for 2001 Ram Truck model 1500-3500 section 9, page 9-4, 9-5, and 9-6 have a Service Procedure for Pistion Grading.
Quote: When rebuilding an engine with the original cylinder block, crankshaft and pistions, make sure the pistions are installed in their original cylinder.
If replacing the pistion(s), make sure the replacement pistion(s) are the same grade as the one being replaced.
If a new cylinder block and/or crankshaft is used, the pistion grading procedure MUST be performed to determine the proper pistion grade for each cylinder.
Next page Fig 8 Piston Grading Mumber Location
NOTE: NEVER INTERMIX PISTIONS FROM ONE ENGINE APPLICATION TO ANOTHER ENGINE APPLICATION. SEVER DRIVEABILITY CONCERNS MAY RESULT.
NOTE: Use the table below when pistion grading numbers are missing or not legible.
PISTION PROTRUSION CHART
IF MEASURING PISTION
IS AND USE
GRADING #: / PROTRUSION /GRADE
IS
245 HP / 215/235 HP
6050 / 6153 / 0. 609-0. 711 / A
/ mm
/ (0. 024-0. 028
IN. )
There is a page and a half of this with diagrams of how to measure. The one thing, that they are absolutly presistent about, is that you do not use the wrong type pistion. There are three grades of pistion. A, B and C. Within that there are nine different PROTRUSION HEIGHTS. And if that isn't enough there is an ALTERNATIVE GRADE IDENTIFICATION METHOD, with grade A, B or C and 3 different heights there. All of these are broken down into 2 columns by horse power as shown in the above example.
On page 14-2 section 14 of the same manual it address the Fuel injection Pump-245 HP Engine.
Description - Although the fuel injection pump on the 245 horse-power engine appears similar to the other VP 44 injection pumps, there are internal differences that make it unique.
Lots of stuff in these factory manuals.
Dont leave home without them. Also keeps the dealer honest when it comes to warranty work if necessary.
