Recently I noticed small drips of power steering fluid when truck is parked for more than a day. It appears to be the low-pressure return line from the power steering cooler to the reservoir. It is the only hose that is wet and when I pull back the mesh shroud there is clean fluid all around the hose. I found the part number (52113929AD) for the new hoses that includes the tee fitting near the bottom of reservoir, but everywhere I look online it says discontinued. The suspected hose that is leaking has a factory 90 degree bend, otherwise I would just buy some 5/8" hose and replace.
Also couple of questions: Does 2006 steering gear box have the bolts on top like 2nd gen that I can tighten to see if that's where my leak is from? PS fluid has coated a lot on the underside and its difficult to pin-point where the leak is coming from. Anybody ever find a trick to getting out bottom reservoir bolt without removing pulley to replace o-ring between reservoir and pump? Anybody know the part number for the tee fitting near reservoir?
Edit to Add: already did the reservoir cap mod to relieve built-up pressure.
