I just finished replacing the steering gear and was bleeding the system when ps pump made a loud wining noise and then the steering got real stiff. I removed the ps pump without removIng the vacuum pump will I be able to realign the new ps pump or should I just remove the vacuum pump and reinstall them together. Also is the ps pump rebuildable and if so where can I get a rebuild kit.
THANKS IN ADVANCE
2000 2500 4x4
THANKS IN ADVANCE
2000 2500 4x4
