Engine/Transmission (1998.5 - 2002) Power Steering Return Line
I'm considering the purchase of a Magnefine filter for my power steering unit. The filters come in three sizes: 1/2, 3/8 and 5/16. What is the size of the return line on our pump? I checked the service manual and did not find it. Maybe I was looking in the wrong place.
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; US Gear EGT and Boost gauges. Amsoil foam air filter and synthetics from nose to tail.
Cummins Power, don't leave home without it
Both the steering gear and hydraulic brake booster OEM return line hoses are 11/32 ID. The text on the hoses say "POWER STEERING RETURN - 11/32 IN. F61-494 30114-R 0759".
I'm replacing both of mine but I'm having trouble finding replacement hose of this size, even from the Dodge parts department. Both Dodge and NAPA told me to use 3/8 line instead. Seems to me, 3/8 may be better because I had to slit both OEM hoses at the pump and couplers to get them off. It was like they were welded on. I checked the new 3/8 hose with the gear box coupler and it seems to fit good and tight.
NAPA suggested their high pressure multipurpose line that has a burst strength of somewhere around 400 PSI. Dodge suggested using their 3/8 power steering return line hose.
I was wondering what other members have used or done to replace the hoses.
I used 3/8 NAPA auto transmission cooler line. The line with the wound nylon jacket, not the soft fuel line looking stuff. No problems with it. I would suggest the 3/8" filter. Let me know how it works out.
I finally found the correct hose (except it's 3/8 ID instead of 11/32 ID) at the local parts store - SP Automotive. It's Goodyear SAE J189, which specifically conforms to the standards for low pressure power steering return hose. I got 4 feet for $5. 89. I didn't get the in-line filter. I plan to make power steering flush and fluid changes a regular part of my truck's maintenance.
