Engine/Transmission (1994 - 1998) power steering?
Engine/Transmission (1994 - 1998) 16 CM Housing not pulling well
Engine/Transmission (1998.5 - 2002) How to drain radiator?
It's clear that your idle is low. Bump it up so it is closer to 850 when in gear, with the AC on. This will also help your starting problem. Your truck should start quickly with no pedal (unless it's below freezing outside).
