Power to gauge lights??
rancho 9000x part numbers for 3G
permatech sprayliner on rocker panels?
Gonna install full pillar Di Pricol boost & EGT and was wondering where you all were getting power forthe lighting. Also was wondering if anyone has installed the full A pillar from Gino's. Do you have to use the stock A pillar under it to make it look right?
Just installed the SRT 10 stock pillar with gauge hole from Geno's Garage last week. Fits just like the one you take out. Some of the holes and clips on the back are different, but on the outside it's perfect.
To find a wire for the backlight in your gauges, tap into the back of the plug wiring for your headlight switch. On my 04. 5, there are actually two orange wires with a brown stripe. You want the one on the bottom row of wires.
That will also power your boost gauge, but only when the lights are on. I found a hot lead under the steering wheel that was a pink wire that was hot only with the key on. So I wired my boost to that one.
Good luck :cool:
Mark,
If I come see you in a couple of weeks, would you have in stock the A Pillar, white face EGT, pyro, and all the odds and ends needed? I'll be in town and ready to get to work!
